Buffer/Unbuffer report
I have some questions about IEC 61850 driver.
1. I want to active Buffer report in zenon so I add report ID from ICD file. What should I do on next stage? Could you explain more about it? How can I check it that works correctly?
2. Is there a way that I could select desired RCB from ICD in import stage?
3. What is functionality of “max. used URCBs” in dirver configuration? It doesn’t limit number of Unbuffer report or tags when I import them from device.
4. Is it possible to change Identification of variable to desired text?
5. Currently zenon doesn’t export SCD file and also doesn’t support SSD file, as you know we need them accordance IEC 61850 standards, what is your comment about them?
I use from zenon 6.21 sp1
Thanks
This is a migrated post! Originally posted on 19.01.2010 by user roberto1978. Please be aware that information can be outdated.
