Bosch MIC IP camera's
Hey
Has anyone tried to get the stream working on the Bosch MIC IP 7000 camera's through an HTML screen type?
If I try, I will get the interface, but not the actual live view stream. All plugins have been installed. It does work in an internet explorer window on the same terminal server.
Also, the snapshot view returns an error: "Authorization Required
this server could not verify that you are authorized to access the document you requested. Either you supplied the wrong credentials (e.g., bad password), or your browser doesnt understand how to supply the credentials required."
I am using the URLs: "http://xxx.xxx.xxx.xxx/snap.jpg?usr=xxx&pwd=xxx" and "http://xxx.xxx.xxx.xxx/live.htm?usr=xxx&pwd=xxx"
This is a migrated post! Originally posted on 08.12.2015 by user cisfransen. Please be aware that information can be outdated.
