Hello everyone,
I am using zenon V16 and would like a text element inside a Smart Object Template to automatically display the name of its corresponding Smart Object instance.
For example, if I create two instances named PCS01 and PCS02, the text element should display PCS01 in the first instance and PCS02 in the second, without having to enter these names separately.
Is there a native way to reference the Smart Object instance name from a text element, such as a placeholder, property link, or system variable?
Releasing the Text property allows me to configure a label for each instance, but my goal is to avoid duplicating the instance name manually and keep the displayed text synchronized if the instance is renamed.
Is this possible in V16? If so, could you explain how to configure it or point me to the relevant documentation?
Thank you for your help.
