Much like the topic suggests I want to have Automatic line coloring apply to breakers that I am having be analog values (Integers). Essentially because I have my breaker status as either open, close, or com alarm I have the variable of the breaker as INT but this does not activate ALC for when the breaker is on. I have tested with Boolean values for the same breaker symbols and those work and the only solution that I don't want to do is put a Boolean breaker underneath my analog breaker but this means that I am sending and coding a Boolean and analog to the Zenon HMI. Is there a way to have the ALC correctly display with integer breakers?
