Hi all,
I am using RGM for recipes. I want to know (if possible) how to auto load a selected recipe when the run time starts.
The reason for doing this is because in b&r PLC they have configurable input output mapping (if emergency ip is assigned to Input 0 then in run time it can be changed to input 1)
So when the Zenon scada run time starts it should automatically load a particular recipe which will have emergency assigned to input 0. This is one example in this case.
Also is It possible to show User through Drop down menu since every time user has to logout and again enter the username.
Zenon version 7.60
Regards
Nivish.
This is a migrated post! Originally posted on 04.11.2019 by user nivish. Please be aware that information can be outdated.
