Annoying project loading loop in SCADA Logic
In Zenon 11, since build 231258, every time a project is compiled in SCADA LOGIC, a progressa bar appears in the Zenon Engineering Studio informing the loading of the entire Zenon project. It is the same progress bar that appears when we open the LOGIC WORKBENCH, but in this case it takes much much longer. This loading process occurs once for each compilation made in SCADA LOGIC (no matter if the compilation is for same or different logic projects). If we compile a logic project 10 times in a row, the loop appears 10 times in a row, and so on. Despite being possible to use the Logic Workbench while this loading proccess is in progress, it is not possible to use of the Zenon Editor until it ends (or we kill the Zenon Editor process through task manager and start it again).
I'm using Zenon 11 build 282289 64 bit.
Is there any workaround for this issue?
Any help would be very appreciated.
Thanks
