I have an image with a control element of the type Compatible Elements (Lock).
Depending on the logged in user, the name and lockCode should be entered in the control element.
My code below:
Sub GetUser()
Dim zUser As user
Dim activeUser As variable
Dim lockCode
Dim zPic As dynPicture
Dim zElem As Element
Set activeUser = thisProject.variables.Item("Username")
Set zUser = thisProject.Passwords.ItemUser(activeUser.Value)
lockCode = zUser.DynProperties("LockCode")
Debug.Print "active Username: " & zUser.name & ", LockCode: " & lockCode
Set zPic = thisProject.DynPictures.Item("Picture_ON_OFF")
Set zElem = zPic.Instances.Item(0).Elements.Item("Logged_User")
End Sub
